!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Republished November
2004
Ford
ExplorerTech
By Fidel
Gonzales
Several months ago,
Off-Road.com was proud to present Gloria & Lee Zimmermann's
outrageous Ford Explorer. With over 19 inches of "VERTICAL" wheel
travel from the Dana 35 TTB, It was right at home where many lesser
vehicles feared to tread. Namely, 4+ rated territory.
But with more capable equipment comes the desire,
nay, "Need" to push those capabilities. Eventually, things will
break, or as in the case of the Explorer's radius arms, "bend".
Well, chalk it up to a lesson learned, but now what? The answer is
simple (that is, if you're Lee Zimmermann ;-). Off came the
offending hardware, and in thier place went a new, far more durable
design.
With more massive tubing, extensive
bracing, and hiem joints sized for a Trophy Truck (literally), the
Zimmermann's Explorer continues to redefine the outer limits of TTB
performance!
From Gloria Zimmermann: "Here is some new information on our front end. The pictures old pictures in the 19" Travel article of the radius arms are now incorrect. After leading Woodpecker at the AZ State Assoc Jamboree in Oct 97, we built new radius arms. The reason, we bent the old ones, and the crossmember." "The new radius arms are built with 2" tubing with 1/3" wall thickness (schedule 160). They are connected to the stock sections of the arms in the same manner as before, but more reinforcing is used. We also double plated the mounting area of the arms (see picture newarm). We are now using 1" heim joints with a load rating of 24,000 pounds (they weigh 2 1/2 pounds each). The ends of the arms where the heim joints connect are made out of solid stock." ![]() ![]()
Follow @Off-Road
