IH Scout Features
LATEST IH Scout Features
Maxxis Creepy Crawler Tires - Review
Maxxis Creepy Crawler tires--only for the professional driver, or will they also work for us weekend warriors?
Oct. 15, 2007 -
Synthetic Winch Lines: The Good and the Bad
>Despite getting stuck we were in high spirits for we knew our WARN XD9000i would have no trouble getting us out. At least so we thought.
May. 01, 2007 -
NOHVCC Forest Service Route Designation Workshops
The U.S. Forest Service (USFS) is under a mandate to complete their Travel Management Plans within the next couple of years. They are looking for public input in the process, specifically when it comes to Route Designation. But, unfortunately most of the
Apr. 01, 2007 -
45th Annual Tierra Del Sol Desert Safari
This year marked 45 years of dedicated wheelin' for the Tierra Del Sol (TDS) off-road club in San Diego, CA.
Mar. 14, 2007 -
Permanent Winch Power for the back of your Truck
Jarred shows how he added a permanently mounted hidden winch to the back of his truck.
Mar. 07, 2007 -
Video: Highlights from 45th Annual Tierra Del Sol Desert Safari
We captured some video from the 45th Annual Tierra Del Sol Desert Safari
Mar. 07, 2007 -
Not So Cheap MAACO Paint Job
Not so cheap Maaco paint job for our Project Off-Road Toyota
Mar. 01, 2007 -
Picking up Your Off-Road Physique
How to sneak in easy exercises when in route to an outdoor adventure.
Mar. 01, 2007 -
LED Headlamp and Tent Heater Review
Now it's time to set up camp. It's not an uncommon scenario. Trying to set up a tent at night or backing that RV...where do you get light to see?
Mar. 01, 2007 -
Jim's Serious Off-Road Buildup Tips for Scout II's w/33" tires
Nov. 17, 2006 -
UNICAT Americas
We recently came into contact with Mr. Avi Meyers, CEO of UnicatAmericas. Unicat has has been making amazing off-road vehicles that double as RV's since 1990 in Germany. This type of vehicle has traditionally only been a delicacy found in Europe, until no
Oct. 15, 2006 -
Reader's Ride - October 2006
Check Andrew's 1977 Scout SS@
Oct. 01, 2006 -
Sometimes Getting Out is Hard Work
I know you've heard this before: if you are going to drive off-road you should always go out with two or more trucks. Many Hummer owners are mavericks with little more than a marginal degree of self-control, however-- so the urge to go out on a trail can?
Sep. 01, 2006 -
Put A Lid On It
One of the biggest decisions to make, after finishing your rc crawler build project, is choosing the right body for it. Sure, the body you run won't affect performance that much, however, it is still important that your rig looks its best, while running t
Aug. 01, 2006 -
The Saga of the Mother of all Rocks
The Mother, the term brings either visions of a sweet comforting matriarch figure or on the other side an overbearing, arrogant, pushy, nasty individual, well the Mother of all Rocks is certainly the latter. (Or was)
Aug. 01, 2006 -
Aug. 01, 2006 -
WE ROCK Western Series #3 Breaks Attendance Records. Losing Streaks & Vehicle Parts
Stuck between a rock and a hard place - that hard place often being a pine tree - best described the courses and driver predicaments offered to top competitors at WE ROCK Western Series Event #3 in Goldendale, Washington
Jul. 24, 2006 -
Waterproofing A Dana 44 Front Hub
The internal-spline Dana 44 front hub uses two tapered roller bearings, and a seal at the inboard end of the hub. At the outboard end of the hub is a drive-in cap that can allow water to enter, bringing grit along with it. Adding to the problem is the lar
Jul. 15, 2006 -
How to Select and Operate a Hand-Held Plasma Cutter
Weekend wheelers, rock crawlers and sand buggy fabricators who experience the benefits of a plasma cutting machine rarely want to return to oxy-acetylene cutting or mechanical cutting processes such as saws, cut-off wheels, shears and snips
Jul. 01, 2006 -
Pnut's Rockers
Custom made high clearance rockers!
Jul. 01, 2006
Follow @Off-Road
