If you’re an avid off-roader and you want an exhaust system, chances are you have run into some issues making some setups fit. Magnaflow recently introduced a new product that we had a chance to check out at the 2010 SEMA show designed to address this issue call the Off-Road Pro-Series Exhaust (ORPS) that is specifically designed to work on trucks and Jeeps with heavily modified suspension.
Whether you have a truck with a basic lift of or a long-travel suspension system, Magnaflow’s new Off-Road Pro-Series exhaust system will fit the vehicle. It features a “turn down before the axle” design that will fit vehicles with highly modified suspension while still producing that aggressive sound for which Magnaflow’s exhausts are known. The ORPS exhaust features a stainless-steel construction in a high-flow, straight-through design. Magnaflow also points out that the ORPS exhaust features hassle-free bolt-on design and it comes with a life-time warranty. Below is a list of applications currently available:
Full Size Gas Trucks
Chevrolet Silverado ½ ton (2007-2010)
Dodge Ram ½ ton (2006-2010)
Ford F150 (2004-2010)
GMC Sierra ½ ton (2007-2010)
Nissan Titan (2004-2010)
Toyota Tundra (2007-2010)
Full Size Diesel Trucks
GMC Duramax (2001-2007)
Dodge Cummins (2004-2007)
Ford Powerstroke (1999-2007)
Compact Gas Trucks
Ford Ranger (1998-2010)
Toyota Tacoma (2005-2010)
Jeep
YJ to JK late model, short and long wheel base
YJ SWB
TJ SWB 2 door
LJ LWB 2 door
JK SWB 4 door
For more info, check out www.magnaflow.com
