Air-Lift-1000-Universal-Air-Spring-Kit-11-26-15
Lansing, Mich. – Air Lift Company has made it easy for drivers to add air springs to coil-sprung vehicles with the new Air Lift 1000(tm) Universal Air Spring kits. Designed for a wide range of SUVs, CUVs, vans, cars and pickups with open coil springs, all it takes are two quick measurements to add high-quality, adjustable air springs to provide up to 1,000 pounds of load-leveling support.
Air Lift 1000 Universal Air Spring kits enhance towing safety and comfort by eliminating squat, trailer sway, rough ride and bottoming out for lighter-duty towing and hauling applications. Finding the correct kit is easy. With an unloaded vehicle, measure the inside height of the coil spring, then measure the inside diameter of the coil spring, then use these two dimensions to find the correct Air Lift 1000 Universal kit number.
Constructed of tough, molded polyurethane, Air Lift 1000 adjustable air springs can be installed with common mechanic’s tools and easy-to-use fittings, which require no drilling in many applications. The kit comes with everything needed for a full installation, including a detailed, easy to follow instruction manual.
The air springs are backed by a lifetime warranty and a 60-day no-questions- asked, money-back guarantee. To view an installation video or learn more about the product and applications, visit www.airliftcompany.com/airlift1000.
