Superlift’s UCA Lift Kits for the 2014-15 Chevy and GMC 1500 pickups have a modern, fitted steel structure that derives its superior strength from the classic ‘I’ beam architecture. Their uniquely engineered design adds strength & durability plus has bonus features that others do not offer. UCA’s come pre-installed with MOOG ball joints & OEM style bushings.
Backed by its Lifetime Warranty, 100% Satisfaction Guarantee and Factory Warranty Assurance Program, this simple & Super-EZ bolt-on installation adds clearance for 33” diameter tires without fender trimming plus ZERO cutting of the rear cross member.
Features:
• Upper Control Arm (UCA) design utilizing laser cut plate steel that are ‘slotted and tabbed’ for precision fitment during fabrication.
• UCA design is oriented in an “I” beam fashion for superior strength.
• CNC machined ball joint socket and bushing eye ring for precise fit.
• UCA includes pre-installed MOOG ball joints and bushings
• No cutting or trimming of the factory drive train
• ZERO cutting of the rear crossmember
• CNC machined billet Aluminum differential drop brackets maintain proper CV axle angles (2WD models do not utilize the differential components)
• CNC formed belly skid pan protects the differential from on and off-road hazards (2WD models do not utilize the skid pan)
• Rear lift is achieved with Block & U-Bolt Kit
• Laser cut & precision conformed top strut mount strut spacers add lift height
• Requires no modification to the stock exhaust
• A simple and Super-EZ bolt-on installation
• Adds clearance for 33” diameter tires without fender trimming
• Comes complete with Superide shocks for the rear
For more information, visit www.superlift.com.
