Superlift-Chevy-Colorado-Lift-7-10-15
Superlift recently released its new Level-It 2-Inch leveling kit for the Chevrolet Colorado and GMC Canyon. The kit, available for both 4WD and 2WD models, provides a more level, aggressive stance while increasing the stability and decreasing the negative body-roll. Get rid of that nose-down factory rake and move up to a true truck enthusiast performance level.
Superlift says the kit is easy to install and is 100% bolt-on. This Level-It utilizes laser cut upper strut spacers and precision CNC machined lower pre-load strut ring, plus hardware to give you the performance ride quality and big look your Colorado or Canyon deserves.
Superlift-Kit-Chevy-Colorado-Lift-7-10-15
•    Allows for the use of plus-size wheels & tires
•    Adds clearance for 265/70R17 diameter tires without fender trimming
•    Enhances appearance by leveling the stance of the vehicle
•    Ideal for restoring height lost from heavy front bumper / winch combos
•    A simple and Super-EZ bolt-on installation
•    Can be returned to stock height
•    No cutting or trimming of the factory drive train
•    Laser cut upper strut spacers & precision CNC machined lower pre-load strut ring add lift height
•    All necessary hardware is included
•    Lifetime Warranty on all fabricated components
•    100% Satisfaction Guarantee
•    Factory Warranty Assurance Program
Tire Sizes:
265/75R16 = 31.6×10.4R16
265/70R17 = 31.6×10.4R17
265/65R18 = 31.6×10.4R18
NOTE: Requires a coil spring compressor for installation.
For more information, visit www.superlift.com.
