WD-40-Jeep1-11062014
Here is your chance to win a true SEMA dream machine, the WD-40 Specialist Xtreme Machine.
WD-40 Company and PowerNation teamed up to build this trick, custom off-roader, based on a 1990 Jeep Wrangler YJ, for the 2014 SEMA Show, and then announced that it will be given away to one lucky sweepstakes winner in June 2015.
Diubbed the WD-40 Specialist Xtreme Machine, the Jeep has an aluminum body and tube chassis, and is equipped with a GM LS V-8 engine, 42-inch tires and Fox Shox coilover shock absorbers at all four corners.
The WD-40 Specialist Xtreme Machine is named after the iconic penetrating oil/water dispersant manufacturer’s more recent line of Specialist products, which feature more specific applications geared toward technical and trade use. The Specialist line currently includes eight products, all of them formulated to exacting standards. They include: Specialist Rust Release Penetrant Spray, Specialist Water Resistant Silicone Lubricant, Specialist Protective White Lithium Grease, Specialist Dirt & Dust Resistant Dry Lube PTFE Spray, Specialist Machine & Engine Degreaser Foaming Spray, Specialist Electrical Contact Cleaner Spray, Specialist Long-Term Corrosion Inhibitor, Specialist Rust Remover Soak.
WD-40-Jeep-prods-11062014
PowerNation, a two-hour block of four automotive shows that air on NBC Sports Network, SpikeTV, the CBS Sports Network, PowerNationTV.com and the PowerNationTV app, includes “Xtreme Off-Road,” “Engine Power,” “Truck Tech” and “Detroit Muscle.” The WD-40 Specialist Xtreme Machine vehicle build will be featured on two episodes of “Xtreme Off-Road” in January 2015, with the sweepstakes to give away the vehicle running from January 2 through May 31, 2015. Tim Lesmeister, vice president of marketing for WD-40 Company says that viewers will get to see the hard work and attention to detail that went into building the WD-40 Specialist Xtreme Machine before putting their hat into the ring to win it via the sweepstakes.
WD-40-Jeep4-11062014“The PowerNation team did a phenomenal job building something that’s both head-turning and unique, and the guys used a lot of our top-of-the-line WD-40 Specialist products in the process,” Lesmeister said.
You can tune into PowerNation’s Xtreme Off-Road for how to win the WD-40 Specialist Xtreme Machine. To learn more about  WD-40 Multi-Use and WD-40 Specialist products, visit WD40.com.
