So your factory carb just won't handle another
rebuild? Perhaps your stocker is just fine but lacks the
performance you're after. In either case, one of the first thoughts
you'll likely have is bolting up a Holley 4bbl, and while you're at
it, an aftermarket intake. Don't worry, you're not alone. Several
million of your fellow gearheads have gone down the path before you
- with outstanding results.
Anyone planning on serious performance tuning
needs the Holley Jet Kit. For about $40, you'll save a lot of trips
to the speed shop, time, money and effort by having a full line of
main jets on hand. Power Valves are not included and available
separately.
Unless you've gone bug-nuts on cam and headwork, an
out of the box Holley 4150 or 4160 series will bring you some
pretty decent performance as long as you stay with in the
recommended CFM range for your engine size and RPM requirements.
When selecting a carb, especially for a relatively low RPM
application like an off-road vehicle, be conservative in your
selection, and realistic in the RPM range where you'll do most of
your driving.
HOT TIP
Leave the "Double Pumpers" for the race crowd. A
well tuned vacuum secondary will return better performance in the
majority of situations you'll encounter, and your gas tank won't
drain faster than a flushing toilet!
Once you've made the decision to bolt
up….say…. a Holley 670 Street Avenger to
a…say…stock 400 CID Ford with an Edelbrock Performer
(Coincidence? I think not!), you'll be rewarded with performance
that leaves you wondering why you ever waited so long to make the
swap. But as impressed as you are with your newfound power, there's
more to be had. Sometimes a lot more.
In reality, the Street Avenger series, like any
aftermarket performance carb is jetted to provide good, all around
performance for a wide variety of applications. In other words,
it's a compromise. When you realize that the 670 will run on
engines as varied as a 302 Ford or a 454 Chevy, you'll also realize
that the jetting requirements for those motors are nowhere near
alike. That's when re-jetting the carb comes in.
For most off-roaders, jetting a carb is a lot like rebuilding an
automatic. Most of us know the basics on how a carb functions, but
there's a big difference between knowing how a carb works, and
making it do magic. Fortunately, since most off-road engines will
never see the high side of 5000 RPM, there's little need to get
into the heavy wizardry of annular boosters, PVCR or Air Bleed
tuning. Most wheelers need only concentrate on the Idle Screws,
Main Jets, and Power Valves.
In a perfect world, we'd all jet our carbs with the aid of a Dyno.
In a semi-perfect world we'd use an exhaust gas analyzer (such as
those used by smog stations, or an on-board model that uses an
oxygen sensor). In the real world though, we often resort to trial
and error.
Before beginning a re-jet, you'll need certain tools. In addition
to a basic hand tool set, your best friend will be a vacuum gauge.
Add a spark plug wrench (because you'll be looking at your plugs
from time to time) and you've got the basics.
Once the float bowl is off, the fun really begins.
Take the time to clean and inspect all the parts on the carb while
it's on the bench. You could come across problems you didn't know
you had before they really cause a ruckus under your hood.
Baseline
To begin the process, evaluate your current set-up. If you're
blowing black smoke, there's soot in the exhaust, or your plugs are
wet or carbon fouled, you've likely jetted too rich. On the other
hand, if you hear the engine detonate (when it's timed properly and
using a suitable grade fuel), the plugs are either spotless or heat
blistered around the ceramic tip, or you experience surging or
backfiring at speed, you're likely too lean - perhaps dangerously
so. While an overly rich mixture can't do much if any damage to
your engine, a lean condition can burn valves, crack heads, knock
holes in pistons, and generally ruin your day.
Once you've established whether you're running on the rich or lean
side, then it's time to do a little jetting. We'll take this
opportunity to tell you that this is a greatly condensed version.
If you are seriously considering jetting your own carb, be sure to
pick up any of the several great books from HP Books or S/A Designs
on the Holley. They go into great detail on the how's, what's,
where's and why's of the modern Holley Carb.
Down In It
After disconnecting the battery, chocking the wheels, and taking
all the usual safety precautions, allow the engine to cool down.
You'll find it's much easier (and safer for the novice carb god) to
work with a cool engine. Hot motors can lead to flash fires and
considerable damage and injury.
Remove the air cleaner assembly and mark the location of all vacuum
hoses, accessories and wires. Once you've stripped the top end of
your engine and exposed the carb, it's a simple 4-bolt process to
get the carb off the intake manifold and onto the bench. While
experts can jet on the vehicle, remember, this is an easier method
for the beginner.
Take the time to clean the carb externally so that no dirt will get
in to the carb body once the float bowls and metering blocks are
off.
When you get to the jets themselves you'll see the
simplicity of Holley's design. When working on the main metering
system, there's few surprises. Tuning is a simple matter of
screwing the proper jet into the proper hole. Determining what size
that jet is can be the tricky part.
Carefully remove the four bolts
holding the primary float bowl. The primary bowl is on the foreword
facing end of the carb - the side nearest the choke/air horn. If
you're using the "blue" gaskets, there's a good chance they'll be
reusable.
At this time you'll see the two main jets for the primary side, and
the power valve centered above them. Gently tap the aluminum
metering block to break it free and remove it from the carb.
Changing jets can be accomplished with a specialty tool available
from Holley, Moroso and others, or carefully use a broad bladed
screwdriver.
When making a jetting change, change only one or two sizes at a
time. For example, if you are too rich with a 65 main jet in the
primaries and 68's in the secondaries, change to a 64/67 or a 63/66
combo rather than making huge jumps in sizes. It's more time
consuming, but you'll get into less trouble in the long run.
As for the power valve, most mild engines respond well with a #65,
75 or 85 power valve installed. Here's where the vacuum gauge comes
into play. You'll need to have a VG installed, or hook up a
temporary diagnostic gauge, running it into the cab.
Take a highway cruise (before pulling the carb of course!) and
determine the vac level at cruise. Ideally, you'll want a power
valve rated 2 inch of vac below the figure you arrive
at.
Installing the PV is a simple matter of unscrewing
the stock valve from the metering block and reinstalling the new
one. Be sure the PV gasket does not restrict flow to the PVCR
channels.
Bolting the carb back up is simply the reverse of disassembly.
Align the gaskets, cover with a light coating of grease to prevent
sticking, and torque to spec.
Note that you'll only find a PV on the primary side. Unless you did
the nasty and bought a race carb, the secondary side will have a
plug where the PV should be.
After sizing the jets and selecting the right
Power Valve, simply reverse the disassembly process and return the
carb to service. Remember that this is a precision metering
instrument and treat it accordingly. A light touch will save you
from replacing costly aluminum bowls, housings, metering plates and
more.
Once you've reassembled the carb and reinstalled all
the connections, you may need to reset the idle mixture screws. To
set the screws, adjust until maximum rpm is reached (per screw) and
you're good to go. While you can hear the RPM increase, you'll be
better served by using a tach to get an accurate reading.
On The Road Again
Since this is a trial and error process Carbslayer, get thee thy
carb upon thee highway, and go forth unto perform thine road
test.
Go out and run the vehicle through it's usual
routine on and off the road. Recheck the plugs and tailpipe for any
signs of change. Don't "trust" seat of the pants feel as the final
word on changes to performance. If you're lucky, you'll get it the
first time, but if not, it's "back to the bench for you kid!"
Remember, this is a time consuming process, but
for most of us, it'll only have to happen once. Then again,
cam/manifold or header changes will require another round or three
of jetting if you're so inclined.
See? Wasn't that hard was it? As we said, this is the condensed
version. Before getting your hands dirty, get a hold of one of the
books mentioned above and become familiar with the parts, pieces
and theories behind the Holley carb. Having a good understanding of
the carb's inner workings will allow you to diagnose any problems,
bugs or glitches easier and will ensure you gain the maximum
performance and economy that your combination will allow.
For More Information On Holley Performance
Products
Holley Powersports Tech
Service
P.O. Box 10360
Bowling Green, KY, 42101-7360
Telephone 270-782-3225
help@support.holley.com
www.Holley.com
