By Fidel
GonzalesWARNING FOR THE
INTELLIGENCE IMPAIRED!New driveway
mechanics should memorize this: The single most important thing you
should know about changing shocks is how to keep the stupid truck
from falling off the jack and squashing you like a bug. We cannot
over-emphasize this.Often when you're
removing shocks, you have to tug or hammer on them. If your
4,600-pound truck is three feet up in the air balanced on the end
of a cheap bumper jack, you could very quickly find yourself with a
face-full of frame rails. This is not conducive to a happy
smile.
Safety is job one before you crawl under a truck.
Use a strong jack - preferably a floor model-and put blocks on the
tires.
So, first off, place your vehicle on level, firm
ground. Even the best of jacks can, and will, sink into sand or
soft ground. Next, get some hefty blocks of wood (I prefer a
4x4-inch chunk), and place them under both sides of the tires on
the end of the vehicle you leave on the ground. We assume you'll be
raising and working on one end at a time. A hefty red brick works
fine, too.Here's something most people
never think about, but it can happen. Make sure the shock is cool
to the touch before you grab it. Shocks can reach close to 300
degrees F under heavy off-roading conditions, often enough to
blister the paint or any stickers on the body of the shock.Let's say you want to change the front shocks
first. Put the parking brake on, put the trans in PARK, or in low
gear if it's a manual. Place the jack firmly under the frame or a
cross-member, and raise the entire front end into the air. Next,
put some stout jack-stands under the frame rail just in case the
jack fails. Make damn sure that the jackstands are straight and set
square against
the frame rails.
Always use strong jackstands. The ones seen here
will hold 10,000 pounds each and cost about $40 a pair.
Remove the wheels and you'll get a clear look at
the shocks. There are several types of mounts:(1) A standard eye-end is the most common. It's just a loop
on the end of the shock that will accept a bolt.(2) A threaded end is simply the straight end of
the shaft with some threads on the mounting area. The end goes
through a hole and is bolted in place.(3)
The Tend (or clevis) is a piece of metal attached to the end
of the shock shaft that usually bolts to a flat surface with a pair
of bolts.
Remove the tire to gain access to the shocks. It's
a pain in the neck to try to work around the wheels.
Once you inspect the type of mounting you have,
pick a selection of tools to match the nuts and bolts. It's a good
idea to organize your work. I usually have a plastic tray for my
tools and another smaller one to handle all the nuts, bolts,
spacers and washers I'm working with. A simple thing like this
makes a lot of difference in ease of work.If the shock nuts look rusty, spray them with a quality
penetrating oil, tap them lightly with a hammer, and give them
another liberal spray. The tapping sets up a vibration that lets
the penetrating oil get into the tight spots.
Three basic shocks mounts: round end, threaded end
and T-end.
Wipe everything clean with a rag before you start
spinning wrenches. There's no sense it trying to twist an oily nut
loose and have the tool slip.Before you
start to remove a shock, get a second jack (a small floor jack
works best) and take the weight off the shock by jacking up the
A-arm (or I- beam or straight axle, depending on your vehicle) an
inch or so.This way, when you unbolt the
shock, nothing will flop downward. Do not use the jack on the brake
disc. It can turn easily and the best jack will slip off. Also, the
brake disc is cast and you could crack or distort it under a heavy
load.
Penetrating oil is a must for removing rusty
bolts.
Now, remove the shock bolts (or attaching
hardware) one end at a time,
paying attention to any spacers or washers that were used. Unless
your new shocks have special instructions with them, they must be
mounted in exactly the same fashion as they were originally.If the shock is hard to remove, gentle prying
with a large, flat-bladed
screwdriver will normally do the trick. If everything is rusted
badly in place, it might be time for more penetrating oil and some
whacking with a hammer. It you want to save the shock you're
removing, never hit the shaft or the body of the shock with
anything. It can put the action in a bind.
Always put a jack under the A-arm (or axle, or
I-beam, etc.) to keep it from flopping down when the shock is
removed.
I've removed some shocks that had badly corroded
threaded ends, so much so that the holding nut couldn't be removed,
and the shaft had to be hack-sawed off. This is not uncommon to
find on old vehicles or trucks that spend some time backing a
trailer down a boat ramp into salt water.SHOCK DOS AND DON'TS
Unless you have a specific reason always
replace the shock with one of the same length and shock
travel.
It you're increasing suspension travel with
some sort of kit, you must use a longer shock to handle the longer
travel.
Buy quality shocks with a good reputation-it pays
off over the long haul. These dual Ranchos mounted on the front of
a Bronco made a dramatic improvement in the ride, both off and on
road.
Always us the shock length and travel specified
by the suspension kit maker.
It you plan to run a longer set of coil
springs, you must run longer shocks to take advantage of the
increased travel.
Never clamp down on a new shock shaft with
pliers or vice grips. This will gouge the surface and quickly lead
to shock seal damage and failure.
Never re-use old bushings or rubber/vinyl
spacers. Always install the fresh ones that come with the new
shocks.
If you have trouble installing bushings in a
shock eye, lightly lube the rubber/vinyl bushing with liquid soap.
Oil or grease can damage some types of bushings, and will quickly
attract dust, grit and dirt.
Always use a lock washer and a good
thread-locking compound on any nuts. I also like to use a cotter
pin if possible.
If your shocks don't come with new bolts,
check your old ones. If they're scored or marred in any way,
discard them. Always use at least a Grade 5 or superior bolt for
shocks. I use a Grade 8 on my personal trucks, and an F9-11
superbolt on my race truck.
Boots or no boots? Read our thoughts in the
article, then decide.
Don't over-shock your truck. Most stock rigs will
handle normal on- and off-roading conditions with a pair of shocks
on each wheel. Many a good ride has been ruined by running three or
four shocks per wheel.
If you can afford it, install a quality set
of adjustable shocks, like the Rancho 9000s. They do make a
difference in performance, and as the shock wears over the years,
you can increase the damping to make up for part wear and shock
fluid degradation.
Never overtighten a shock mounting.
This can put the shock in bind and prevent it from pivoting while
it goes through its stroke.
If your shock won't quite fit into the
mounting ears, it's okay to take a little bit of material off the
bushing material Don't bend the mounting ears out, as this will
weaken and possibly crack the metal.
Normally, its easier to remove the bottom
shock bolt first. This will let you wiggle the shock around and
possibly provide easier clearance to get a tool in. Some top shock
mounts are in really tight spots and hard to get to.
Typical shock location on the rear end of a
truck.
Double check all your nuts and bolts after you're
done, especially if you have any extra pieces left over. Often, a
shock kit will come with a drawing of where the bushings go in
relation to the spacers and such. Follow the instructions
exactly.
When you first drive your rig with the new
shocks, you might he disappointed initially, because the ride might
feel too stiff. This is normal, especially on shocks with big
shafts. It will take some time for them to seat in the seals and
scrapers before they work smoothly. Good old Rancho RS 5000s take
about 100 miles of driving before they settle in and you learn to
appreciate them.
Adjustable shocks can-and should-be set
lighter during break-in, then firmed up later on. Do not pre-judge
a shock before break-in.
Some shocks are angled inboard at the top. This is
claimed to lend an anti-sway quality to the ride.
Most shocks come with boots. I personally do not
use boots,
even though they look great. They tend to trap moisture and
dirt
inside, and have even seen sections of a boot get pinched between
the shock cap and shaft, and get sucked into the seal. There are
those who disagree with my thoughts on this, so you make the
call.
Don't put any stickers on your shocks. I know
it looks cool, and the manufacturers love to see their name all
over the place, but a large sticker will actually make the shock
body run hotter and reduce its ability to cool off.
Here's a typical dual rear shock setup.
If you buy shocks with remote reservoirs like the
racing guys run,
always put the hose clamps near the ends of the reservoirs, not the
middle, as this will tighten the barrel of the reservoir and make
the floating piston move sluggish. Bladder-type reservoirs do not
have this problem.
Always mount reservoirs away from hot areas,
and use quality stainless-steel hose clamps.
There you have it. Now go and shock
the world.By Fidel
Gonzales
